clear eaps counters
clear eaps counters
Description
Clears, resets the counters gathered by EAPS for all of the EAPS domains and any EAPS shared ports configured on the switch.
Syntax Description
Default
N/A.
Usage Guidelines
Use this command to clear, reset the EAPS counters.
The counters continue to increment until you clear the information. By clearing the counters, you can see fresh statistics for the time period you are monitoring.
To display information about the EAPS counters, use the following commands:
The following command clears, resets all of the counters for EAPS:
clear eaps counters
This command was first available in ExtremeXOS 11.6.
Platform Availability
